Reply
R6700 and Apple not communicating
barryaz1
Follower
Since the latest (security) update (.35) on my R6700 both my MAC and iPhone take forever to log on and consistently lose connectivity. A nearby PC has had no problems with it
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Re: R6700 and Apple not communicating
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.
If it isn't too late, and you aren't locked out completely, first note down the settings – screen grabs can help here.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 263 views
  • 0 kudos
  • 2 in conversation
Announcements
