Reply
R6700 cant connect tftp to fix firmware issue
Rossmon
I have a R6700 that I bought over a year ago.  It hasn't been used.  It was interuppted during a firmware update, and I couldn't fix it then (because of time) so I had to go back to ISP provided modem.  It gave amber power light when turned on. by following various directions on here:
I have gotten it into recovery mode (white flashing powerlight) by holding reset and turning it on.
I turned on tftp in windows features.
I downloaded the latest firmware from netgear, and put it on the desktop
I opened up my ethernet and set static IP address 192.168.1.10, subnet 255.255.255.0, default gateway 192.168.1.1
I opened cmd and put in: Desktop>tftp -i 192.168.1.1 put R6700-V1.0.1.48_10.0.46.chk
The response is: Connect request failed
When I ping, I also get no response
C:\Users\****\Desktop>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data
Request timed out.
Request timed out.
Request timed out.
Request timed out.
I'm stuck and can't seem to get further... I've tried using static ip as 192.168.1.2, I don't know what else to do.
Also, not sure it's relevant, but my computer doesn't have an ethernet port, so I'm using an adapter in USB, (and it's showing up as Ethernet 2 on the control panel)
When I attempt diagnose on the properties screen for the ethernet 2 I get the following error:
"Ethernet 2" Doesn't have a valid IP configuration
Anyway, please help...
Thanks,
New Dad, Single income, Teacher's salary
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 7
antinode
Guru
Re: R6700 cant connect tftp to fix firmware issue
   Ok.
> [...] my computer doesn't have an ethernet port, so I'm using an
   Is "Ethernet 2" the interface which you configured with those
parameters shown above?
Message 2 of 7
TFTP causes lots of grief. It isn't always straightforward.
If you get stuck, a Google search for something like "unbrick my router" can deliver useful videos.
Does your various moves so far include a "recovery mode" reset?
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 7
Rossmon
Yes, that is what put it in recovery mode, that led to the blinking white light.  I attempted the transfer after that, while it was in this receive mode.
Message 4 of 7
Rossmon
yes, it is.  It is the only ethernet that I have.
Message 5 of 7
Rossmon
Message 6 of 7
myersw
Master
part of the tftp process is being able to ping 192.168.1.1 from the PC. Are you able to do that? That would verify that the Ethertnet dongle is configured correctly. It sounds to me like the dongle is not working. Follow the tftp instructions to the letter and it should work. It a step is not working like the ping command then come back here with issue.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2043 views
  • 0 kudos
  • 4 in conversation
Announcements
