Reply
Highlighted
R6700 firmware conflict with Android devices
Updated firmware to V1.0.1.36.  None of my wireless Android devices reconnected, all other wireless devices reconnected.  Had to revert back to V1.0.1.26 for the Android devices to reconnect (V1.0.1.32 didn't work either).  Problem with firmware updates?
Message 1 of 5
Highlighted
Master
Re: R6700 firmware conflict with Android devices
Hi bowling,
Is it on both 2.4Ghz and 5Ghz that your Android devices are unable to connect?
Try changing the channel.
If still the same, reset and reconfigure.
Message 2 of 5
Highlighted
Did ethernet devices work when you were on 1.0.1.32 or 36? I had a similar problem when I went from 1.01.22 -> 32 or 36. Additionally, I also had less frequent issues with 1.0.1.26 on my R6700.
Message 3 of 5
Highlighted
FYI - no connectivity under 2.4Ghz and 5Ghz; no connectivity using other channels.
Message 4 of 5
Highlighted
My only issues were with wireless connectivity to Android devices under 1.0.1.32 and 36.  Never had any issues with firmware updates through 1.0.1.26.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 256 views
  • 0 kudos
  • 3 in conversation
Announcements
