Orbi WiFi 7 RBE973
Reply
R6700 needs to reset constantly
GrayHairs
Hello All
I'm using firmware v1.0.2.8 on r6700 and it keeps losing connection several times a day.  is this a firmware issue or do i need a new router?
Message 1 of 8
r6700v1
Apprentice
Re: R6700 needs to reset constantly
First reboot, then upgrade to V1.0.2.16_10.0.57. I never have to reboot this version. If that doesn't work, try another wall wart with the same output voltage and amps if you can find one.
Message 2 of 8
GrayHairs
netgear updated the firmware automatically, cheers hoping that was the issue.  i'll update when it goes down again.
Message 3 of 8
GrayHairs
Internet just went down again. Nighthawk app said we had strong connection speeds this evening. Now nothing!?
-GrayHairs
Message 4 of 8
GrayHairs
Enabled QoS hoping this will prioritize bandwidth.
Message 5 of 8
GrayHairs
QoS didn’t help. Time to get a new router ?
Message 6 of 8
paillassou
Apprentice
Exactly same pb on R7800 since the latest firmware updates
Message 7 of 8
Werehatrack
Mine was flaky until I downgraded to the firmware that was recommended above (which predates the Armor misfeature), and TURNED OFF AUTOUPDATE.  The first time I stepped it back, I neglected to nix the autoupdate, and it ran just fine for a bit under 18 hours before it reinstalled the bugs and then crashed before lunch.  Since stepping it back and killing the update option, it runs solid and stable.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 976 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
