Reply
R6700 says its Google Assistant Compatible but it is not.
carismatico78
Follower
This link Nighthawk Specs specifically says that my R6700 is compatible with the R6700 but it is not.  Am I missing something?  Is there an update that will make my R6700 a R6700 V2?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
William10a
Master
Re: R6700 says its Google Assistant Compatible but it is not.
Not that I know of even the main part of model number is the same as the version number shows that the router was changed in its hardware in some way, unless they both use the same firmware  I see no way.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 158 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
