Reply
R6700 setup with switch and cable modem
etp
Question on running two R6700 off the same cable modem. Can I run a LAN cable from the Cox modem to a 1GB switch and then run two R6700s off LAN cables at opposite ends of the house?
Can it be an unmanaged switch or must it be a managed switch?
Seems I remember trying this years ago and could not get it to work.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
LeeH
Prodigy
Re: R6700 setup with switch and cable modem
Is your Cox modem a router/modem that can provide DHCP service?  That would make things much easier.
If it is a router/modem then you can put both the R6700's in AP mode and use the COX device as a router.
Message 2 of 4
etp
Only has one LAN output.
Message 3 of 4
LeeH
Prodigy
One LAN port should not be a problem if you are connecting it to a switch but it is unlikely that the modem is a router if it only has one LAN port.
Can you call your ISP and see if they can give you a modem that is also a router?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3777 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
