Orbi WiFi 7 RBE973
Reply
R6700V3 Downstream QOS speed issue
timsalu
Hi Guys, I just purchased this router and I'm having some speed issues when QOS downstream is enabled, currently running latest FW.
My ISP speed is 50 MB, when QOS enabled, I get 1mbps in average from speedtest.net, is this normal? I\m getting it on both bands, 2.4 abd ghz.
Any ideas? Should I avoid using this feature?
Thanks.
Message 1 of 6
Accepted Solutions
timsalu
Re: R6700V3 Downstream QOS speed issue
What I changed was the cable from cable modem to router to cat 6 cable and it worked. perhaps my old cable was defective.
Message 5 of 6
All Replies
JamesGL
Master
Hi timsalu,
What priority did you set on your device under QoS?
How many devices are affected?
Message 2 of 6
timsalu
Is working fine now, all stable and working as expected. Thanks.
Message 3 of 6
JamesGL
Master
Hi timsalu,
Please share the things you have done that made it work.
Message 4 of 6
timsalu
Message 5 of 6
JamesGL
Master
Hi timsalu,
Thank you for sharing. I will tag your response as accepted solution.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1452 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
