- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6700v2 Ethernet ports don’t output internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I plug an Ethernet cord into any of the ports 1-4 and than connect the other end to example computer or another device needing Internet it doesn’t have internet connection. The wifi works fine but using the router as a means for hardwire internet access non of the ports work they are orange.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6700v2 Ethernet ports don’t output internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I fear that "doesn't have Internet connection" could be down to many things.
Tell us more.
What is at the other end? A Windows PC?
What tells you that there is no Internet connection?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@michaelkenward Is correct.
We need more info to help you.
1. what modem/gateway are you connecting to?
2. what firmware is on the router?
3. You're able to connect to the router but not to your gateway (hint again on what gateway you have). Are you able to ping the gateway using its address?
4. what does your internet statistics page show?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
