Reply
R6700v2 and Win10
Hey all, hopefully someone has run into this. I recently upgraded my XFinity to 600mps service. When I log on with my iMac to the 5GHz radio I'm seeing around 500mps based on speedtest which is great. Dropping to the 2.4 and speed drops to around 140, which is to me expected. When I start a Win10 session however via bootcamp, 2.4 connection yeilds around 50mps, while the 5 connection is almost nil. Has anyone seen this? Am I missing a simple setting perhaps? On my old router both radios worked fine under Win10, but I needed to upgrade to handle the boosted speeds.
Thanks!
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 4
Guru
Re: R6700v2 and Win10
If you search google for "bootcamp slow wifi windows 10" there's a bunch of bunch of different causes. None of which are caused by the router. Its usually driver related because of using bootcamp to run windows 10.
I'd try searching google with more specifics. aka specific wifi card.
CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP
Message 2 of 4
Thanks! I'm in the middle of searching now.
Message 3 of 4
Guru
Apple does have a forum specific to bootcamp that would probably be a better help for you as they're the experts in it.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 186 views
  • 0 kudos
  • 2 in conversation
Announcements
