Reply
Highlighted
R6700v2 not producing gigabit speeds on FiOS (ethernet or wired)
I recently upgraded speeds from 100/100 to gigabit connection. Moved to a new place and earlier today the FiOS tech was able to get everything set up. I passed on their router since historically, I've had no issue with the nighthawk. It's connected to the ONT directly.
I just got the chance to play with the speeds and I'm getting 275/275 wirelessly and roughly 100/100 via cat5e ethernet. As I continue my move into the new house I'll try with Cat6.
I played with a couple of settings, for whatever reason IPv6 was disabled, I set it to auto. QOS turned off, WMW on, no luck.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Highlighted
Re: R6700v2 not producing gigabit speeds on FiOS (ethernet or wired)
Forgot to mention, for what it's worth im on firmware V1.2.0.62_1.0.1
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 309 views
  • 0 kudos
  • 1 in conversation
Announcements
