Laprinciss's avatar
Laprinciss
R6700v2
Can not access my admin. wifi setting, can some one help
  • JamesGL's avatar
    JamesGL
    Aug 14, 2017
    Hi Laprinciss,
    Reset the router to factory default. Press the reset button at the back panel of the router until the power turns blinking amber.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Laprinciss,
    Are you getting any error message when trying to access routerlogin.com or 192.168.1.1?
    • Laprinciss's avatar
      Laprinciss
          Yes ,  it's not letting me log on. I put admin for username ,an password for the password .
             Tel me if I'm doing anything wrong. I'm trying to chand my wifi password , and I can't even log on .
      • JamesGL's avatar
        JamesGL
        Hi Laprinciss,
