Reply
R6700v3 lost internet. Amber light
Hbodley
Tutor
Lost internet during streaming and now it won’t reconnect. Has a amber light over the internet symbol. I can plug directly into my modem and internet works fine.
Model: R6300v2|AC1750 Dual Band Gigabit router
Message 1 of 14
Hbodley
Tutor
Re: R6700v3 lost internet. Amber light
No replies? Is this forum dead?
Message 2 of 14
Guru
No its not dead, but it was the weekend. This is the community forum where members of the public try to help out. We're not on here 24/7.
What modem are you using?
What firmware is on the router?
What have you done to try and fix it?
Factory reset/reboot?
were you doing anything to cause the change? moving devices/changing settings/etc
Details help more than "the lights amber, whats wrong?"
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 14
Hbodley
Tutor
The modem is a Calix (not sure of model it was supplied by my provider). I reset the router so it’s firmware would be whatever came with it. It was bought 11 months ago. Problem is I don’t have a laptop with a LAN port to log into the router. Nothing was moved or changed the family was streaming Netflix and it just quit. I bought a new model of the same router yesterday because kids needed internet for school and we stream all TV. Powered it up and everything worked fine so I’m guessing something happened to the proxy settings in the router? Any ideas what to try?
Message 4 of 14
Hbodley
Tutor
The tech at my provider just checked everything on their end and can’t find anything wrong. He says he can see the MAC address for the router but the router is not making the request for the IP address. Thoughts?
Message 5 of 14
Guru
look on the calix. there should be a model somewhere. That's key
so you've replaced the router and its still having the same issue?
Tends to imply an issue with the modem if more than 1 device is having issues.
Message 6 of 14
Hbodley
Tutor
No. I said I bought a new router ( Netgear AC1750 also) and everything works as it should. That would make me believe the problem is in my router not the modem.
Message 7 of 14
Hbodley
Tutor
Modem is a Calix GigaPoint 801Gv2. Model 100-04796 11.
Message 8 of 14
Guru
So the new one works fine?
And you bought the same model?
I'd try re-installing the firmware on the non-working device, factory reset it, and then try installing it.
Message 9 of 14
Hbodley
Tutor
Yes and yes. How can I reinstall the firmware without an internet connection?
Message 10 of 14
Guru
you can download the firmware to a pc and manually install the firmware.
look in the manual for "manual firmware update".
Message 11 of 14
Hbodley
Tutor
So reinstall the firmware and then do a factory reset? Or do you mean reinstall the firmware and if that doesn’t work do a reset?
Message 12 of 14
Guru
in this order.
1. install the firmware
2. Factory reset the router once its re-installed and fully booted.
3. manually install the router. do't use a backup.
Message 13 of 14
Hbodley
Tutor
I will do that tomorrow.. Thanks
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 798 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
