Reply
R6700v3 preloaded Express VPN
Davidsnr
Follower
This router was bought because it was supposed to have Express VPN preloaded on it. However when trying to watch content on my I pad from the UK I was told it was not available in my location (Spain). If the router has Express VPN preloaded how do I tell it to locate me in London, England.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
microchip8
Master
Re: R6700v3 preloaded Express VPN
This forum is for the official NETGEAR firmware only. Ask the folks of ExpressVPN, which is third party
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 3
Guru
like @microchip8 says, expressvpn is a 3rd party firmware. its not official.
So if you bought it from expressvpn, it might have it preloaded and just need to be turned on/activate/whatever. Check with expressvpn on that.
or you can installi to it but it'll void your warranty and potentially brick your device.
https://www.expressvpn.com/support/vpn-setup/app-for-routers-netgear/
but for either, you need to go through expressvpn since its 3rd party firmware. You'll also only get support on there
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 284 views
  • 0 kudos
  • 3 in conversation
Announcements
