Reply
R6700v3 setup with spectrum Ubee gateway
Robmc66
Follower
Hello, does anybody know how to set this configuration up so I have a proper internet connection the gateway is on 192.168.0.1 and the net gear is on 1.1....
Message 1 of 2
antinode
Guru
Re: R6700v3 setup with spectrum Ubee gateway
> [...] does anybody know [...]
   Someone who read the User Manual might.  Assuming that you want to
keep your (unspecified) "spectrum Ubee gateway" as your main (only)
router, and you expect to run an Ethernet cable between it and your
R6700v3, then configuring the R6700v3 as a wireless access point should
do the job.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Set up the
router as a WiFi access point".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 185 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
