Reply
R6700v3
April33
Follower
R6700v3
I can’t login. I reset to factory settings holding down the button for 7 seconds and it still asks me for security questions of which I never set up.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Guru
Re: R6700v3
If its still asking the questions, it wasn't fully factory reset. When the router is booted up fully, hold the reset button until the lights on the router change. Its usually 7-10 seconds but hold it until the lights change. Shouldn't be longer than 30 seconds.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 337 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
