Reply
R6850 stop FUNJSQ
Arbalest
R6850 stop FUNJSQ
Does anyone know how to turn off FUNSQJ?
It seems it is necessary to "reboot the router and stop Funjsq and other applications not related with the firmware update." The penalty for not doing so is bricking the router.
This question has been asked before, but I cannot find an answer that explains anything. Is there a switch in the router control software?
Model: AC2100|Nighthawk AC2100 Smart WiFi Router
Message 1 of 11
Accepted Solutions
Arbalest
Re: R6850 stop FUNJSQ
Updated manually without any problem? Sounds good. Thanks. I'll try that.
Message 5 of 11
All Replies
microchip8
Master
what is that? I've never heard of it
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 11
Guru
I agree with @microchip8
Never heard of it or needed to do anything with it.
I've had 1 post that had the same issue but they updated manually and didn't have any issue.
I'd recommend updating over a hardwired connection to the router for the best results updating. I've done this for years and never had an issue updating.
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 3 of 11
Arbalest
What is FUNJSQ?  A good question. I can't find any explanation.
Message 4 of 11
Arbalest
Message 5 of 11
microchip8
Master
I don't know where you read that, but such a service does not exist on NG routers
Message 6 of 11
phdgolf
This update is for any R6### routers that have a firmware update to V1.1.0.76
After 2 hours on the phone with Netgear support, I have found out the following on funjsq.
1.  Funjsq is a download accelerator that is embeded within the firmware.
2.  Funjsq is from China.  (Google funjsq or Funjsq.com)
3.  Funjsq is enabled only if QoS is enabled
If QoS is enabled, you must disable it, apply changes and reboot the router.  It is suggested that you make a backup of the current firmware configuration before updating the firmware to the new version.
You can then do the firmware upgrade, either manually or "automatically" from the router Admin Basic page.
Enable Qos only after successfully upgrading the new firmware - AT YOUR OWN RISK
Good luck and best wishes.
Message 7 of 11
Arbalest
Right. I did update manually, and everything seems fine. At least I didn't brick the router!
Message 8 of 11
Arbalest
It was a warning in the automatic update in Admin software theat came with my R6850. Netgear's warning, but there is no explanation or instructions.
Message 9 of 11
Arbalest
Thanks for this. Good of you to pass on your hard-earned knowledge! I find that QoS is not enable, and I'm leaving it that way, following you (implied) warning.
A manual update worked. I'm saving your reply for future reference.
Message 10 of 11
Arbalest
Right. I couldn't find anything myself. But phdgolf posted some information.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2792 views
  • 1 kudo
  • 4 in conversation
Announcements
