- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6900 Nighthawk setup wizard disabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used Nighthawk R6900 in the USA for a while. Everything worked fine. Now i am using same router in India for ACT ISP. To configre PPPoE, option 'Internet setup wizard' is disabled. I need this option, to avoid frequent login of ACT ISP protal page. Please suggest ASAP.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi rkinhyd76,
Make sure the router is not setup as an access point.
Check this KB below. Uncheck the "Enable AP mode".
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6900 Nighthawk setup wizard disabled
Hi rkinhyd76,
How is the device connected to the modem?
Try this article.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for suggestions. I am not using modem. From the wall point, i am directly connecting to router and using WiFi. I tried to follow the steps as per link, at
"STEP 3. Under the Basic Tab, click on the Internet." Internet hyperlink is disabled. Please suggest. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi rkinhyd76,
