Orbi WiFi 7 RBE973
Reply
R6900 after firmware updated, no internet connection after doing checking firmware updated again
mluvw47
Re: R6900 after firmware updated, no internet connection after doing checking firmware updated again
That doesn't seems in my case.
On my router, I changed it back the DNS "Get Automatically from ISP", then apply the change.
Did a firmware update, it shows that message again. The only way to get check firmware update work is use Primary DNS as 8.8.8.8
Message 26 of 27
Guru
You can also set your secondary server to 8.8.8.4.4 if you wish (another google server).  Or set it to the comcast server.
Message 27 of 27
Top Contributors
Discussion stats
  • 26 replies
  • 13301 views
  • 7 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
