Reply
Highlighted
R6900 nighthawk USB connection
Can’t connect Seagate Backup Hub Plus Hard Drive 6TB from its USB 3.0 port or 2.0 port. I have a Lacie hard driver currently connected to NetGear without any issues? Is there any tricks I should know?
Message 1 of 4
Highlighted
Guru
Re: R6900 nighthawk USB connection
   Firmware version?
> Can't connect Seagate Backup Hub Plus Hard Drive 6TB from its USB 3.0
> port or 2.0 port. [...]
   I assume that that means that you can connect it, but that it doesn't
work when you do.  I know nothing, but a Google search for:
      site:netgear.com Seagate Backup Hub Plus
finds many things, including:
      https://community.netgear.com/t5/x/x/td-p/1324619
Message 2 of 4
Highlighted
Thanks for the tip. I had checked the community post already before post my question. Unfortunately someone said the Seagate backup hub will not work with NetGear R6900. I can’t see the device in Genie under Attached Devices.
Message 3 of 4
Highlighted
Routers don't play ball with complicated USB devices that require fancy drivers to get them to work.
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 593 views
  • 0 kudos
  • 3 in conversation
Announcements
