- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6900P Firmware Upgrade Order
- Mark as New
- Bookmark
- Subscribe
- Permalink
My R6900P router currently has firmware version V1.3.2.134
Both the Nighthawk app and the NetGear Genie app report that the firmware is up to date.
However, the NetGear support page lists V1.3.3.140 and V1.3.3.148 as also available.
I'm wondering if I it is ok to manually update from V1.3.2 to V1.3.3 with no issues?
And if so, do I have to update to V1.3.3.140 and then go to V1.3.3.148 in sequence?
Thanks. It would be helpful if their support page told you which prior versions can update to the listed version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6900P Firmware Upgrade Order
Manual update is the method I usually recommend. Especially if you can do it hardwired.
You should be able to jump all the way to the latest version (.148) without issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
