Orbi WiFi 7 RBE973
Reply
R6900P doesn’t have Coax
cluelessoldman
I’m trying to setup r6900p but it does not have a coax cable input. The nighthawk setup app keeps asking me to connect via Ethernet but I don’t have a household Ethernet port. Did I purchase the wrong type of router?
Message 1 of 12
Accepted Solutions
Guru
Re: R6900P doesn’t have Coax
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
@cluelessoldman wrote:
I have Xfinity cable and no modem. I think the issue is that my (current)C6300 netgear router may also act as a modem. So I may not have purchased correctly. Do you think I can keep the r6900p and just put a modem in front of it? Thanks for the reply I appreciate it!
Message 8 of 12
All Replies
microchip8
Master
A router needs a modem to connect to using a UTP (Ethernet) cable. You cannot feed it coax. A cable modem has a coax port
Message 2 of 12
Guru
Who's your isp?
I'd recommend getting a modem separate from the router versus getting a modem/router combo device anyway.
so you might not have gotten what you thought you were but it might be for the better.
Message 3 of 12
cluelessoldman
I don’t have a modem now though, which is why it confused me. I think my (old) netgear C6300 may be a modem AND router and maybe that’s why it always worked. Thanks for the reply!
Message 4 of 12
cluelessoldman
Message 5 of 12
Guru
The c6300 has a modem only node you could put it in and connect the new one to
Message 6 of 12
Yes. Dead easy.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual for the C6300 Change the Router Mode.
Message 7 of 12
Guru
Message 8 of 12
Kitsap
Master
Someone ought to ask the question, why did @cluelessoldman replace the C6300 in the first place?
Message 9 of 12
Excellent question. Especially when they bought an R6900P. Not what you'd call cutting edge technology. Same AC1900 wifi technology.
Message 10 of 12
cluelessoldman
I was relaxing it because it seemed like my signal was decreasing over time, like the range seemed to be decreasing. Also I have had this router for more than a few years now, I figured a new and better one would work. The associates at Best Buy suggested this router, of course it now seems I shouldn’t have listened to them!!! Thx for replying though I do appreciate it.
Message 11 of 12
Yup. They sold you something that is little better than the thing you already own.
But there is nothing stopping you from getting a more capable router and using that behind your current modem/router.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1756 views
  • 4 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
