Orbi WiFi 7 RBE973
Reply
R6900P
Jozy
R6900P
Hi, I am a bit behind in updating firmware. Since my last update, version R6900P-V1.3.1.44_10.1.23 and R6900P-V1.3.1.64_10.1.36 were released. Do I have to apply both versions or can I just go the latest being R6900P-V1.3.1.64_10.1.36? Thanks.
Model: R6900P|Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Accepted Solutions
Re: R6900P
You can go straight from where you are to the latest.  You do not need to upgrade incrementally.  You can also downgrade if you wish, to any FW you want.
Message 2 of 3
All Replies
Re: R6900P
Message 2 of 3
Jozy
Re: R6900P
thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1554 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
