Reply
R7000 1.0.7.6 firmware update
james_7000
Follower
Port Forwarding labels are scrambled upon updating firmware. The Forwarding user label does not match what it was. Say I had a label for port forwarding called Port 3389. for actual ports 3389. The label woulf change to Port 21 and others would be mixed up.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
IrvSp
Master
Re: R7000 1.0.7.6 firmware update
That can happen if you updated from and older firmware version.
First thing to try, re-boot the router, see if that fixed it. If not, you have to RESET the router and RE-ENTER (not upload a save settings file) all options you need.
Sorry, but that is what is needed to be done. NG doesn't always play nice when you upgrade over and older version. Works fine for some, others, nope.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2205 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
