Reply
R7000 1.0.7.6 firmware update
jayhaitch
Follower
So, trying to update the firmware.  I go to netgearlogin page but the username/password [as printed on router] wont accept.  So go to retrieve password page, enter the product serial number but the "continue" button wont click. any ideas how to get around this?
thanks
Message 1 of 2
Re: R7000 1.0.7.6 firmware update
Which password are you talking about?
There should be two on the router, wifi and interface.
Unless you have changed it, the password for the interface (http://www.routerlogin.net or http://www.routerlogin.com) is password. (That's why it is a good idea to change it.)
The username is admin.
If you have changed the interface password and you cannot remember it, then you will have to do a factory reset of your router.
This is all explained in the manual:
R6700 | Product | Support | NETGEAR
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1769 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
