- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 1.0.9.x reboot cycle
- Mark as New
- Bookmark
- Subscribe
- Permalink
My R7000 was bricked. After finally figuring out how to configure Terminal on MacOS to let me Ctrl-C the boot process so I could turn tftpd on, I can now reflash the firmware. Every version of the 1.0.9.x firmware that I've tried so far, inluding 1.0.9.6, 1.0.9.10, 1.0.9.26, 1.0.9.34, 1.0.9.64 (latest) continually reboots upon startup; presumably from a software crash. Not sure what is going on. I guess this wny so many people said "don't upgrade your firmware".
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I spent way too much time on this. 😞
Yes! I ordered a new power adapter. This one: https://www.amazon.com/gp/product/B06XWHS8G2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
And now the R7000 is working again.
So, if you think your firmware upgrade is causing your constant reboot cycle, it might just be your power supply. OMG.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 1.0.9.x reboot cycle
Just installed 1.0.8.34 and it came up all the way. Then rebooted after 15 seconds. Ugh. I'm enormously frustrated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downgraded firmware to 1.0.7.12_1.2.5 and it's been running for 5 minutes so far. It's a record. Letting it run now...
Any clues why this is happening R7000 people?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router reboots when I connect a wifi device with firmware 1.0.7.12. Downgrading to 1.0.7.10. What version should I be using or is there some proceedure I'm missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could be having power supply issues?
I assume you have been doing the FACTORY RESET after each firmware change and re-entering settings manaully, not using a saved configuration? Not doing this can mask the problem and keep it happening.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sometimes I can do the FACTORY RESET. Sometimes I can't when the unit won't stay up long enough before rebooting on its own.
- Mark as New
- Bookmark
- Subscribe
- Permalink
0) plugged router into different surge protector
1) performed factory reset
2) waited for router to come back up, rebooted router and hit Ctrl-C in minicom window
3) started tftpd on router
4) sent R7000-V1.0.9.64_10.2.64.chk to router
5) router is rebooting continually (update it's hung)
ACSD >>acs_candidate_score_intf(2330): intf check failed for chanspec: 0x100b acsd: Netgear selected channel spec: 0x1009 control channel:9 Request finished Failed to open file '/etc/avahi/avahi-daemon.conf': No such file or directory ###################################mount openvpn mtdblock19 [ 29.710000] Empty flash at 0x000aa150 ends at 0x000aa800 [ 29.880000] Empty flash at 0x00441474 ends at 0x00441800 [ 29.910000] Empty flash at 0x004430d4 ends at 0x00443800 [ 31.960000] Empty flash at 0x00d9b0f0 ends at 0x00d9b800 [ 32.820000] Empty flash at 0x04033a9c ends at 0x04034000 [ 32.830000] Empty flash at 0x04034ac8 ends at 0x04035000 Digital core power voltage set to 1.0V Decompressing...done
6) All lights are blicking and router output on minicom has stopped here:
ADDR 0000000000111111111122222222223333333333444444444455555555556666 0123456789012345678901234567890123456789012345678901234567890123 00 +++++++++++++++++S+++++++++++++X++++++++++++++++++++++++++++++++ Decompressing...done
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like a hardware or power supply issue. No firmware version can fix that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
1) plugged router into different surge protector
2) factory reset
3) let router boot
4) hard reset, interrup startup to get CFE> prompt
5) start tftpd
6) put R7000-V1.0.9.64_10.2.64.chk onto router
7) Router reboots about 6 times
😎 Router hung on 7th reboot with all lights blinking and was bricked here:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. So I'll throw it away. Bummer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have another power adapter with the same specs you can try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Note, it runs for 10-20 minutes on 1.0.7.10 firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll try another power adapter, looking for one now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
