Reply
Highlighted
Tutor
R7000 - 5GHz extremely slow, 2.4GHz works fine
Hi all, my apologies for a redundant thread, but I am looking for any help I can get before doing an RMA on my router.
To start off, I started noticing speed and connection issues with my R7000 shortly after I upgraded it to the very buggy and now unavailable, 1.0.6.28. I downgraded it to 1.0.4.30 and things haven't seemed to change on the 5 GHz band. My 5GHz is essentially unusable on any of my devices, and speed tests are consistently showing me speeds between 5-10 Mbps on average. My 2.4 GHz network speed tests are usually very high around 75-100 Mbps.
I've isolated it to the router by doing the same speed testing on multiple devices (Laptop, iPhone, iPad) with generally the same results as above.
I also tried downgrading the router further to 1.0.4.28 and upgrading to the current beta version and the results are unchanged.
If anyone has any ideas or suggestions I would appreciate the help, thanks!
Message 1 of 8
Highlighted
Prodigy
Re: R7000 - 5GHz extremely slow, 2.4GHz works fine
Message 2 of 8
Highlighted
Tutor
Thanks storm, forgot to mention that I have done that (multiple times in fact).
Message 3 of 8
Highlighted
Guide
Have you tried to remove/forget the 5g wifi profile and recreate it?
Message 4 of 8
Highlighted
Tutor
I just tried this, no luck.
Message 5 of 8
Highlighted
Master
Hi The_King,
You may try to load the beta firmware available at the link below.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/any-new-info-or-update-to-new-firmware/td-p/...
Message 6 of 8
Highlighted
Tutor
Hi JamesGL - As indicated in my original post, "I also tried downgrading the router further to 1.0.4.28 and upgrading to the current beta version and the results are unchanged."
Message 7 of 8
Highlighted
Master
Hi The_King,
Please check your inbox.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2629 views
  • 1 kudo
  • 4 in conversation
Announcements
