Orbi WiFi 7 RBE973
Reply
R7000 - 5Ghz signal (and channels) suddenly extremely weak
rfsux
Follower
I have to stand ten feet away from my router to be able to connect to my 5Ghz signal. Before I could be farther away. Now I get 2.4Ghz speeds when I change the 5Ghz channel to <149 numbers. But I get horrible speeds or no connection at all when I change the 5Ghz channel to >149 numbers, unless I stand really close to the router. It was never like this until yesterday. I left the router off for a night, rebooted it and electronics, and checked for updates, but as I walk further from the router my devices cannot locate or connect to the now drastically weak 5Ghz channel . Has anyone solved this problem before?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: R7000 - 5Ghz signal (and channels) suddenly extremely weak
Hi rfsux,
What is the firmware version of the router?
https://kb.netgear.com/000055563/R7000-Firmware-Version-1-0-9-28
Message 2 of 3
All Replies
JamesGL
Master
Hi rfsux,
Message 2 of 3
JamesGL
Master
Hi rfsux,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1946 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
