Reply
R7000 AC1900 internet keeps dropping
CarlAndJaysen
Follower
We have the Nitehawk AC1900. We bought it a year ago, and disconnected it immediately cause it was dropping a lot but recently decided to reconnect it as advised by our internet provider as it was better than what we were using. Which is true but it keep dropping service. Is it common for the internet to drop often and have to reboot on the app every day if not multiple times a day?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Guru
Re: R7000 AC1900 internet keeps dropping
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 5
JEF13
We have the same issue. Have had the router about 14 months and it keeps dropping every night. I have to reboot. Anyone find a solution to this?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 3 of 5
JWS9518
Apprentice
It seems several versions of the firmware for this router have that issue.   Try updating to the latest version 1.0.11.128 or the oldest known stable version .42 .   I currently use .128, which does have the reboot issue, but usually only once every day or two with the network coming back in about 5 minutes or via a quick reboot.
,42 is old but fairly stable as far as that goes.
No idea why netgear can't figure out the stability issues, but it has been a problem with this router for a few years now.
Message 4 of 5
Guru
Do you have the C7000 cable modem?
Testing
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 275 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
