707lineman
Sep 17, 2017Aspirant
R7000 AP Mode Can't reach admin panel after modem change
So my setup before I changed it had a Arris Cable modem from Suddenlink, a AC1900 Router for wifi (Wifi was turned off on the Arris Modem) I connected a cat5 from the port of the modem to the "internet" port of the AC1900. I was able to connect wirelessly to the AC1900 and be able to access both the router and the modem (192.168.1.1 and 192.168.0.1) I recently changed from wireless to hardwired on my gaming tower, Which I ran directly to the modem. Now I cannot access the AC1900 either between 192.168.1.1 or routerlogin.net. I have the router set at 192.168.1.1 due to some devices needing to be in that ip range. I cannot change the settings of the modem as it's locked from the provider.
Baciscally I need help getthing access to the AC1900 while hardwired into the modem.
Modem 192.168.0.1
AC1900 192.168.1.1
Try a factory reset on the router. Reset the modem also. Then disconnect the wired connection between the router and your gamer and see if it still connects the old way. It should work the way you have it but sounds like something wierd is going on.
- sktn77aVirtuoso
Have you tried resetting the router?
- 707linemanAspirant
Yes, not a factory reset but a soft reset
- sktn77aVirtuoso
