Orbi WiFi 7 RBE973
Reply
R7000 Adsl stops broadcasting WiFi
Jonny1983iep
I live in uk so router is vdsl adsl no separate modem.
After about a day the WiFi stops broadcasting. I tried splitting the 2/5 and disabling guest but it stops and a reboot brings it back up again.
Has anyone see this before and has a long term fix then rebooting the router every day?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
Re: R7000 Adsl stops broadcasting WiFi
Can't be the R7000 then.
If it is the D7000 modem/router, then you might get better replies, and find other answers, over in the appropriate section:
DSL Modems & Routers
Message 3 of 4
All Replies
antinode
Guru
> R7000 [...]
> I live in uk so router is vdsl adsl no separate modem. [...]
   Then it's not an R7000.  Perhaps some D7000 variant?  Look at the
product label.  Firmware version?
Message 2 of 4
Message 3 of 4
Jonny1983iep
you are correct my mistake it is a NETGEAR D7000-200UKS
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1098 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
