Reply
R7000 Beta FW 1.0.5.60 (New beta) vs V 1.0.6.40 (Old beta) - difference?
BOZGBOZG
Star
Just wondering what the difference between these two beta firmwares is? Why the shift backwards in terms of numbering? It's a bit confusing that a newer beta would have a lower number than an older beta.
Message 1 of 16
01R
Luminary
Luminary
Re: R7000 Beta FW 1.0.5.60 (New beta) vs V 1.0.6.40 (Old beta) - difference?
does this newer beta fix all the ipv6 problems and thouroput problems ?
and all the problems when watching or listening to spotify to long causing the routers firwall to spazz out n disintigrate the stream makin it crap ?
btw all firmwares be4 this had problems with the firewall i think i did report this be4 when i said about trying to watch sling tv for a long time and the router crappin out
Message 2 of 16
fibercarbon
Tutor
wondering as well
Message 3 of 16
JohnNadeau
Apprentice
We've been running Beta V1.0.6.40_1.1.90 on two R7000's since it was released.  We haven't experienced any problems on either Router.
Sure would be nice if NetGear chimed in here to let us know if we're talking a step backwards, as the number sequence implies, or spells out the differences between the two versions 🙂
Message 4 of 16
01R
Luminary
Luminary
i tried it an its broke im tryin to listen to spotify n watch some vids an spotify keeps choking  checkin the logs theres tons n tons of fin scans ? same sorta thing happend with sling tv  tons n tons of fin scans attacks an after the triel i chose not to subscribe if the stoopid router was gona do this and it is the routers fault
whats with the fin scans attacks ?
Message 5 of 16
ElaineM
NETGEAR Employee Retired
The firmware 1.0.6.40 contained Arlo support.
We're taking a little step backward to focus on the stability of the previous official released firmware (1.0.5.48) before adding the Arlo feature.
ElaineM
NETGEAR Community Team
Message 6 of 16
BOZGBOZG
Star
Is that the only difference, Elaine?
Would you recommend downgrading to 1.0.5.48 if you do not need Arlo support?
Message 7 of 16
ElaineM
Yes, that's the main difference.
Just to be clear, that firmware version 1.0.5.48 was an official firmware that was pulled out due to some bugs found.
The new beta 1.0.5.60 is the continuation of that version that fixes the reported issues.
If you experienced the said bugs reported then you may want to try updating to 1.0.5.60.
ElaineM
Message 8 of 16
sir_bazz
Guide
So may I ask if all the fixes listed in 1.0.5.60 are also in the older 1.0.6.40 or is there more?
Message 9 of 16
Gandolph
Star
Good question.  I am running the older beta and am now wondering whether I should install the newer beta with the lower revision number.
Message 10 of 16
fibercarbon
Tutor
wondering the same thing
Message 11 of 16
SkyOwl
Guide
If you don't need ARLO support, I would goto the latest beta (1.0.5.60).  Its working great for me.
Message 12 of 16
sir_bazz
Guide
Would you still upgrade even if the older beta is working without issues?
The 1.0.6.40 beta is only the second firmware I've had without causing a problem with the 2.4ghz network after a week or so usage.  The previous one was way back at 1.0.3.61_20140605_QA
One thing I've found with this router is that when you find a firmware that works, you need to stick to it.
With that in mind, the only reason I'd try the newer beta is if there were additional code fixes or security fixes etc. Else I'll stick with 1.0.6.40 which is currently at 26 days uptime.
Message 13 of 16
SkyOwl
Guide
I too had been using 1.0,6.40 since it came out without issues.  ElaineM's sticky post has a list of fixes etc for the new beta and the improved 2.4ghz connectivity appealed to me.  So I loaded it and yes I'm having less irritations with my string of 2.4ghz IP cameras.  All else appears to work as well or better than the .40 beta and not having to deal with configuring arlo support when I don't use any arlo products is a plus for me.
If any of the points in ElaineM's sticky appeal to you, by all means try .60.  For me it seems to be (qualitative judgement) slightly better with still no issues.
Message 14 of 16
sir_bazz
Guide
Thanks for the reply.
I did review the change list and improved 2.4G was the feature? that appealed here also.  No drop outs with 1.0.6.40 but signal strength is curiously lower, (measuring via inSSIDer), than 5G where my PC's are located around the house.  Guess thats good for 5G capable devices but not so good for our 2.4G devices.
Ahhh what the heck, I'll give it a go.  Can always flash back if needed. 🙂
Message 15 of 16
fibercarbon
Tutor
Im still on the fence of flashing the new beta. I have been on V 1.0.6.40 for about 5 days now.. Cant make up my mind
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 5202 views
  • 4 kudos
  • 8 in conversation
Announcements
Orbi WiFi 6E
