Reply
R7000 Can't turn off WPS PIN after firmware upgrade
NG_Jim
Initiate
I upgraded to V1.0.9.64_10.2.64 firmware on my R7000. Hard reset and then entered all my settings manually again. If I uncheck Enable WPS Pin and click apply, the page comes back with Enable WPS Pin still checked. Tried multiple times, resets, reboots. Same result.
Settings not sticking should never happen. Downgrading to last firmware unless someone's got a fix. Thanks.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 6
yddtime
Luminary
Re: R7000 Can't turn off WPS PIN after firmware upgrade
Clear the browser cache and try changing the setting again. If that doesn't work then roll back to version 1.0.9.42 and wait for 1.0.9.88 to be released.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NEW-R7000-FW-Version-1-0-9-88/m-p/1768661
R7000 is in the recycle bin
Message 2 of 6
243wd3
Initiate
Hi. Same issue on "Firmware Version V1.0.9.88_10.2.88". Is there a fix for disabling WPS or do we have to roll back "V1.0.9.88_10.2.88" also?
Message 3 of 6
NG_Jim
Initiate
I had to roll back to V1.0.9.60_10.2.60
Then I was able to disable WPS again. Netgear come on!
Message 4 of 6
243wd3
Initiate
Well this sucks! Looks like this is the only viable method for now till Netgear figures out a fix. Thanks
Message 5 of 6
yddtime
Luminary
The WPS issue was the least of my problems with 1.0.9.88. Most of my 30 devices couldn't stay connected for more than a few hours. They would connect again after a reboot but 3 hours later the connections would drop again.
I gave up and bought a new router (not Netgear)
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1823 views
  • 3 kudos
  • 3 in conversation
Announcements
