Reply
R7000 -- Cannot turn off wireless isolation
RealistcBadger
Follower
Hello all, I have a R7000 router and I need to disable wireless isolation. I believe this is the cause of the issue, because my desktop and my laptop cannot ping each other. I went to the netgear setup, then advanced wireless settings, but there is no option to disable isolation. I also checked in basic wireless settings, and other tabs, but no luck. I have firware V1.0.3.68_1.1.31. Thanks in advance.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
microchip8
Master
Re: R7000 -- Cannot turn off wireless isolation
Are they by an chance connected to the Guest network and not the main one? Because only the Guest one has isolation
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 4
antinode
Guru
> my desktop and my laptop cannot ping each other. [...]
   "cannot" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
   What are their IP addresses?  Actual "ping" command"?  Actual "ping"
output?  Or, what, exactly, are you doing, and what, exactly, happens
when you do it?
> [...] I have firware V1.0.3.68_1.1.31. [...]
   That's years, and dozens of releases, behind what's current.  You
might try something newer.  1.0.9.64 and 1.0.9.60 have been getting
some complaints around here, so you might want to start with, say,
1.0.9.42.
   Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
   You might also try a settings reset, and manual reconfiguration:
      https://community.netgear.com/t5/x/x/m-p/1718906
> [...] only the Guest one has isolation
   Only the Guest networks _should_ have (optional) isolation.  And
firmware should be bug-free, too.
Message 3 of 4
ADBDRABEN1999
Model: MR1100|NIGHTHAWK M1
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2119 views
  • 0 kudos
  • 4 in conversation
Announcements
