- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 DHCP connectivity issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Nighthawk R7000 router had been working fine until the last few days. It seems like that the DHCP is not working properly.
I'm using the range 192.168.1.2 - 192.168.1.254. But on all my devices (cabled and wifi) I'm getting the following IP-adress:
192.168.192.xx. There're no issues when I switch to static.
The firmware is version V1.0.4.30_1.1.67.
Any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have found the issue. There was a conflict with my Horizon Media Box by Samsung. You can use this box also as a router and it provided me a wrong IP-adres. I have disconnected the Horizon from my network and it works properly now. So I didn't use the reset option. Thanks for your help.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 DHCP connectivity issues
Have you tried connecting 192.168.192.1, or, whatever the gateway address is, to see what the device is? Perhaps it's you ISP modem / router combo? Do you run the ISP device in bridge mode, or is it an actual modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for your reply.
I have tried to make a connection with 192.168.192.1 without success. Also ping gave me a time out. My ISP modem isn't wifi and I don't run both (modem and router) in a bridge.
I have checked my settings and DHCP is on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the R7000 is configed with the 192,168.1.x subnet and you are confident the R7000 is Serving the wrong IP Addresses, I would reset the R7000 to factory default.
- Mark as New
- Bookmark
- Subscribe
- Permalink
