Reply
R7000, DLNA/MediaShare, USB, and folders
dtk
Tutor
Tutor
Is it REALLY the case that I can not point the DLNA server to a subdirectory of a attached USB drive? I see no way to do this. Even the 'edits' on the 'USB Storage (Advanced Settings)' page do NOTHING. 'Create Network Folder' button does nothing. Quite irritating this.
Message 1 of 2
dtk
Tutor
Tutor
Re: R7000, DLNA/MediaShare, USB, and folders
ok, so literally seconds after posting I entered the correct search terms and solved the edit issues. WTF does the Netgear UI suddenly use popups when editing share information when every other page doesn't. Need to hire a UX master Netgear, engineers can't design UIs.
I also found this
http://forum1.netgear.com/showthread.php?t=85418
which gives a way to sort of do what I want with DLNA and subfolders. The Asus firmware does this easy peasy, eh? miniDLNA has the API for it, lets add it Netgear.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6155 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 6E
