Reply
R7000 Disconnection problems
robot2
keeps disconnecting every now and then, on wifi & ethernet and i guess it reboots itself?
using a D-Link DSL-526B ADSL2+ modem and it stays the same and doesnt loose connection when the R7000 resets, any help?
Message 1 of 4
robot2
Re: R7000 Disconnection problems
also just noticed there is heat, is that normal? its not fully hot but its warm..
Message 2 of 4
Redtulips7
Apprentice
Yes it get worm on touch,I am using CM Smiley Very HappyCooler
Nighthawk AX12[RAX120]
Nighthawk X10[R9000]
Message 3 of 4
robot2
i used to sit the mdoem ontop of the R7000 moved it off last night and hasnt disconnected since
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2175 views
  • 0 kudos
  • 2 in conversation
Announcements
