Reply
R7000 Firmware 1.0.9.58 firmware 5GHz not working
naaaj11411
Tutor
I installed 1.0.9.58 on my R7000 a couple nights ago using the web interface. Ever since the udpate, my 5GHz isn't working well. My iPhone, Fire TV, Macbook Pro all keep dropping connections. When I try to reconect it says invalid password. Something is wrong with this firmware.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 12
naaaj11411
Tutor
Re: R7000 Firmware 1.0.9.58 firmware 5GHz not working
Actually, it wasn't just 5GHz that was problematic. 2.4GHz was dropping after a while, too, and I couldn't re-connect.
I tried wired connection, which also stopped working after a few minutes.
I rebooted, and then used wired connection immediately to downgrade to 1.0.9.42, and now it seems to work fine.
Given this experience, I should turn off the automatic firmware update feature.
Message 2 of 12
shamarin
Virtuoso
My 5 GHz devices connection good without any drop of the connection with 1.0.9.58. With 1.0.9.42 FW i was having such issues that you describe.
Message 3 of 12
Retired_Member
Not applicable
Could be someone messing with us nobody else has problems
Message 4 of 12
glennf14
Tutor
I'm having very similiar issues with my R7000 on the 5ghz band on firmware V1.0.9.58_10.2.58, including the incorrect password issue. I downgraded the firmware and that just seemed to make things worse (devices on the 2.4ghz band couldn't reach the internet). I should've done a factory reset after downgrading to see if that cleared things up. Instead I re-upgraded and then did the factrory reset. Things have gotten slightly better, but running a continuous ping on the gateway (192.168.1.1) when on the 5ghz band has some interesting results. Every so often, the ping will continuously timeout for a couple minutes and then come back to life. Notice the latency spikes just before and after the drop. Smells like a memory leak perhaps?
Also, it's ludicrous to suggest to customers that they factory reset their router after every firmware upgrade. If you can't develop your software to upgrade somewhat gracefully, then you're doing it wrong. How about folks like me that have almost 50 DHCP reservations? Copying/pasting all those back in ain't fun.
See below:
64 bytes from 192.168.1.1: icmp_seq=82 ttl=64 time=1.096 ms
64 bytes from 192.168.1.1: icmp_seq=83 ttl=64 time=2.252 ms
64 bytes from 192.168.1.1: icmp_seq=84 ttl=64 time=2.543 ms
64 bytes from 192.168.1.1: icmp_seq=85 ttl=64 time=2.870 ms
64 bytes from 192.168.1.1: icmp_seq=86 ttl=64 time=2.567 ms
64 bytes from 192.168.1.1: icmp_seq=87 ttl=64 time=2.125 ms
64 bytes from 192.168.1.1: icmp_seq=88 ttl=64 time=50.696 ms
64 bytes from 192.168.1.1: icmp_seq=89 ttl=64 time=197.584 ms
Request timeout for icmp_seq 90
Request timeout for icmp_seq 91
Request timeout for icmp_seq 154
64 bytes from 192.168.1.1: icmp_seq=155 ttl=64 time=987.250 ms
64 bytes from 192.168.1.1: icmp_seq=156 ttl=64 time=0.838 ms
64 bytes from 192.168.1.1: icmp_seq=157 ttl=64 time=2.869 ms
64 bytes from 192.168.1.1: icmp_seq=158 ttl=64 time=0.890 ms
64 bytes from 192.168.1.1: icmp_seq=159 ttl=64 time=0.967 ms
64 bytes from 192.168.1.1: icmp_seq=160 ttl=64 time=0.780 ms
Model: R7000
Message 5 of 12
dan-dunham
I had the exact same issue with 1.0.9.42 and had to drop back on fw version. Keep an eye on things, you might need to downgrade another version.
Message 6 of 12
glennf14
Tutor
Thanks! I'll give that a shot. Also, looks like Netgear has removed 1.0.9.58 from R7000's support page. Hopefully we'll hear from them soon on this thread...
Model: R7000
Message 7 of 12
ablatt
Apprentice
What's the latest known 'good' firmware version for the R7000?
Message 8 of 12
glennf14
Tutor
Update: Last night I downgraded to 1.0.9.42, and after downgrading I did a factory reset. I reapplied all my settings manually then rebooted. Everything seems to be back to normal and is stable. I let ya'll know if I hit any issues with 1.0.9.42, but so far so good.
Model: R7000
Message 9 of 12
shamarin
Virtuoso
For me the latest best FW is removed 1.0.9.58 version. I have no issues with it, even for 5 GHz wireless devices.
Message 10 of 12
dan-dunham
Cool, let us know in a few weeks how stable it is, I might try that one on a bit.
Message 11 of 12
shamarin
Virtuoso
It's stable. My 5 GHz smart TV connecting very well with out any disconnections.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2080 views
  • 1 kudo
  • 6 in conversation
Announcements
Orbi WiFi 6E
