Reply
R7000 Firmware Changed IP from 192.168.1.1 to 10.0.0.1 see logs
My log shows the following in October. I found this because I couldn't connect to my printer and found the network IP changed.  I have Xfinity modem connected to my R7000.
[DHCP IP: (192.168.1.12)] to MAC address FCSmiley Very HappyB:B3:B7:F9:84, Sunday, Oct 16,2016 23:53:05
[DHCP IP: (192.168.1.4)] to MAC address 00:1B:EA:CD:58:FC, Sunday, Oct 16,2016 23:52:51
[DHCP IP: (192.168.1.4)] to MAC address 00:1B:EA:CD:58:FC, Sunday, Oct 16,2016 23:34:00
[DHCP IP: (192.168.1.4)] to MAC address 00:1B:EA:CD:58:FC, Monday, Oct 17,2016 23:52:50
[DHCP IP: (192.168.1.4)] to MAC address 00:1B:EA:CD:58:FC, Monday, Oct 17,2016 23:33:58
[DHCP IP: (192.168.1.5)] to MAC address E0:88:5D:61:23:4E, Monday, Oct 17,2016 23:27:41
The following three logs separated by a line space all occured on Oct 18th but note the IP address has changed as well as date to 2015
[Internet connected] IP address: 10.0.0.6, Thursday, Jan 01,2015 00:00:11
[Internet disconnected] Thursday, Jan 01,2015 00:00:10
[Initialized, firmware version: V1.0.5.64v1.7] Thursday, Jan 01,2015 00:00:04
[Internet connected] IP address: 10.0.0.6, Thursday, Jan 01,2015 00:00:10
[Internet connected] IP address: 10.0.0.33, Thursday, Jan 01,2015 00:00:07
[Initialized, firmware version: V1.0.5.64v1.7] Thursday, Jan 01,2015 00:00:03
[Internet disconnected] Thursday, Jan 01,2015 00:00:02
The following log was sent OCT 19 note odd dates and time.
[Time synchronized with NTP server] Tuesday, Oct 18,2016 15:35:14
[email sent to: theopope@gmail.com] Tuesday, Feb 27,2018 17:57:39
The following log was sent OCT 19th date and time has been corrected
[email sent to: theopope@gmail.com] Wednesday, Oct 19,2016 00:01:03
This one was sent the 20th
[Time synchronized with NTP server] Thursday, Oct 20,2016 23:41:24
[Internet connected] IP address: 10.0.0.33, Thursday, Oct 20,2016 23:41:14
[email sent to: theopope@gmail.com] Thursday, Oct 20,2016 00:01:03
Essentially all my remaining logs  are the same until now.
Any ideas on why this happened?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Master
Re: R7000 Firmware Changed IP from 192.168.1.1 to 10.0.0.1 see logs
Hi Theophelous,
The router's IP will automatically changed once it detects that it is connected to another router. Check if the modem is a modem and a router as one and might be using the 192.168.1.1 IP which triggers the changing of the IP address of the router to 10.0.0.1.
JamesGL
Community Team
Message 2 of 5
Master
Hi Theophelous,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
Message 3 of 5
If that were true why didn't the IP change immediately when I installed in in June?  The modem is Xfinity brand that is 10.0.0.1 and the R7000 worked fine on 192.168.1.1 for months then the change in October???  It doesn't make sense to me.
Message 4 of 5
Master
Hi Theophelous,
What is the IP address of the Xfinity modem? This is normal for the NETGEAR routers to change the IP once it detects that it is connected to modem/router with the same IP range. The changes depends on the network setup that you have. If the modem is just a plain modem then it will not change to 10.0.0.1.
JamesGL
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4001 views
  • 0 kudos
  • 2 in conversation
Announcements
