Orbi WiFi 7 RBE973
Reply
R7000 Firmware Updates from v1.0.7.12
Cobweb
Hi,
I recently found my Nighthawk R7000 router and I'd like to use it again.  It's current firmware version is 1.0.7.12, and I'd like to know if the updates are cumalative and I can just download and update to 1.0.11.100 (and the hotfix, too of course) or is there a specific firmware update path like when I updated my ReadyNAS (6.2.2 -> 6.2.5 -> 6.5.2 ->6.10.x).
Thanks 🙂
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: R7000 Firmware Updates from v1.0.7.12
> [...] I'd like to know if the updates are cumalative and I can just
> download and update to 1.0.11.100 (and the hotfix, too of course) [...]
   I've never seen any requirement for a stepped update on these
devices.  Presumably the (usually worthless) Release Notes would say
something if it were.
   I'd run the experiment.  I'd also do a settings reset after after any
big-jump update (because of my great faith in Netgear router firmware).
Message 2 of 4
All Replies
antinode
Guru
Message 2 of 4
Cobweb
@antinodeThanks for the reply, I've never encountered stepped firmware updates on routers before either but maybe because I've recently been updating my NAS firmware I thought I'd better check in case I bricked it.
I updated it to 1.0.11.100 and the hotfix this morning and touch wood - all seems good 🙂
Message 3 of 4
@Cobweb wrote:
@antinodeThanks for the reply, I've never encountered stepped firmware updates on routers before either .....
It has happened, but rarely. The Orbi system went through it once, when there had to be an intermediate update to get around a memory issue of some sort.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1508 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
