Reply
R7000 Firmware Version 1.0.9.26 - Hot Fix - breaks smart devices
wojtosz
Initiate
R7000 Firmware Version 1.0.9.26 breaks smart deviecs comunication. Downgrade to 1.0.9.18 turns all functions back.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 8
schumaku
Guru
Re: R7000 Firmware Version 1.0.9.26 - Hot Fix - breaks smart devices
Whatever smart devices are. One might guess you talk of devices using different variants of IGMP multicast for device discovery, communications, ... like say Chromecast?
Message 2 of 8
wojtosz
Initiate
I have:  R7000 as router, Yamaha CD-NT670 as music player, iPhone SE (x2) with Yamaha MusicCast controller installed, TV LG LF592V. All connected with WiFi 2,4 GHz.
After firmware upgrade to 1.0.9.26, I was not able to connect between any of my devices, including ping any of it or obtain IP via DHCP from the router on Yamaha. As I saw the description of 1.0.9.26 Hot Fix, there are some fixes to the Wi-Fi disconnect issue caused by a flood of broadcast traffic and security fixes as well. For now, I can not debug the traffic on 1.0.9.26 again, so I can not say that IGMP multicast is the only problem.
Message 3 of 8
dkishton1486
I only see the firmware 1.0.9.18 how did you get a newer version?
Message 4 of 8
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This can be especially try for wifi, if that is the issue. There's a steady trickle of messages here from people who fixed wifi with a reset.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 8
antinode
Guru
   Visit http://netgear.com/support , put in your model number, and
look for Downloads.  Under "Pick a Topic" (NOT under "Firmware and
Software Downloads"), look for "Security Hotfix Downloads (Beta
Firmware)".
   It's probably not how I would have organized these things, but that's
not unusual.
Message 6 of 8
dkishton1486
Ahh I see... If it is an issue id just go back to the firmware that was working
Message 7 of 8
Visit the support pages:
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
Read the Top Support Articles.
There is some logic to Netgear's strategy. New firmware goes through a quality assurance process that takes time. If it has been testing new firmware with beta victims, that won't have been through the QA mill. In effect, a Hit Fix has been beta tested by not QA'd.
There's a chance that a Hot Fix won't make it through QA. Or something newer will come along. So a Hot Fix may never make it on to the list of published firmware.
Just another user.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2929 views
  • 1 kudo
  • 5 in conversation
Announcements
