Orbi WiFi 7 RBE973
Reply
R7000 Firmware downgrade turns on Arlo and now can't turn it off
zeaj07
Guide
I was running 1.0.6.28 and was having issues.  Checked the community here and found that this FW had been pulled so I downgraded to 1.0.4.30.  Now, the 2.4Ghz band has both my SSID and the
 NETGEAR52-arlo_246612 being transmitted on top of one another.  I can't find a setting to turn it off in the 1.0.4.30 firmware.  Should I use a beta version to solve this or is there some really simple thing I've overlooked? I see many are enjoying a stable 1.0.5 beta; can someone point me in the direction to obtain that version so that I can turn off the arlo?
thx
ed
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
TheEther
Guru
Re: R7000 Firmware downgrade turns on Arlo and now can't turn it off
A factory reset should wipe it out.
Message 2 of 4
All Replies
TheEther
Guru
Message 2 of 4
zeaj07
Guide
Thanks for the answer without any additional commentary about my lack of brain cells. Worked perfectly.
Message 3 of 4
Einrich
Star
They should not advertise R7000 as Arlo compatible if they then proceed to disable it with firmware updates.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2847 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
