Reply
R7000 - Gigabit Ethernet vs AC1900 WiF speed and reliable?
PhamHuyBao
Hi Guys,
I wonder how speed and reliability comparison between Gigabit Ethernet cable vs. AC1900 WiFi (either USB or PCI adapter).
I want my computer to be able to WOL, thus I opt to use Gigabit Ethernet cable, but not sure if there is any USB/PCI AC1900 WiFi adapter can do the same, and it is, how is the speed/reliability compare to Gigabit Ethernet?
Thanks
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Accepted Solutions
TheEther
Guru
Re: R7000 - Gigabit Ethernet vs AC1900 WiF speed and reliable?
AC1900 will never be as fast or reliable as Gigabit Ethernet.  The best I've seen is around 650 Mbps, but that's standing <5 feet away from the router.  I'll get around 300 or so Mbps from 10 to 15 feet away.
Message 2 of 2
All Replies
TheEther
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2676 views
  • 1 kudo
  • 2 in conversation
Announcements
