- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000: Had to change wireless network to one designated NETGEAR35-5G
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I originally set up my R7000 router i set it to the NETGEAR35 network, but noticed I had other channels/networks listed that included one labeled NETGEAR35-5G. About a week ago I started having problems with the NETGEAR35 network on all connected devices. I then switched to the NETGEAR35-5G network and things seem to be OK. I do have a problem now with connecting my echo dot which does not recognize the NETGEAR35-5G network. Has anyone come up against this issue and how did you get around it to connect the echo device?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try changing the channel used by the regular NETGEAR35 network. Better yet, run a Wi-Fi analyzer app that will show you what channels are being used around you. You can find Wi-Fi analyzers for iOS, Android, Windows and MacOS.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000: Had to change wireless network to one designated NETGEAR35-5G
Many thanks for the explanation and advice
