Orbi WiFi 7 RBE973
Reply
R7000 - IP Address Reservation settings won't save.
StanH
Tutor
I am using these instructions:
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
but I can't make the reserved IP perminent. The attached picture shows the page that I got to that I can't implement. It is at [Advanced] [Setuuup] [LAN Setup]. I am probably leaving out a step. I have reached
What steps should I perform at this point to save the reserved IP address that I have specified?
I am not sure the link to picture is working. When I click it,  it wants to save rather than open.
Message 1 of 3
antinode
Guru
Re: R7000 - IP Address Reservation settings won't save.
> [...] I can't make the reserved IP [address] perminent. [...] I can't
> implement. [...]
      https://community.netgear.com/t5/x/x/m-p/2109384
>    "can't" is not a useful problem description.  It does not say what
> you did.  It does not say what happened when you did it.  As usual,
> showing actual actions (commands) with their actual results (error
> messages, LED indicators, ...) can be more helpful than vague
> descriptions or interpretations.
   Still true.  A vague description of what does _not_ happen is less
useful than a clear description of what _does_ happen.
      8. Click the Apply button.
   It's the green one that says "Apply".
> I am not sure the link to picture is working. [...]
   It's fine.  What your web browser does with it is an argument between
you and your web browser (about which I know nothing).
> [...] When I click it, it wants to save rather than open.
   Worst case: Save it someplace, and then open the (newly saved) file.
Message 2 of 3
StanH
Tutor
1 Initial conditions:
All devices blocked except T1700 and TOWER, both of those are computers. TOWER is shut down. Internet is connected through the R7000. Routerlogin.net is not accessable unless Internet is connected.
2 At [Advanced] [Setup] [LAN Setup], pushed the [Apply] button. The attachment shows the page just prior to pressing [Apply]. After apply, finished I rebooted the R7000.
3 Reconnected the network to the Internet. Login to routerlogin.net. This produced:
"Windows has dectected an IP address conflict"
In Event Viewer: [Error] "The name "SERVICCO :1d" could not be registered on the interface with IP address 192.168.1.2. The computer with the IP address 192.168.1.1 did not allow the name to be claimed by this computer."
4 In Genie network map, 192.168.1.2 is the T1700, the name of the Windows 10 computer that I am running. Apparently the R7000 router blocked the computer I used to give instructions to the router!!!
5 Startup of TOWER (00:04:5A:80:4A:2F), IP is unchanged at 192.168.1.9
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 435 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
