Reply
R7000 - Limiting Lan Speeds and I figured out why -- Its the Access Control Feature
MichaelFL
Apprentice
Its the Access Control being enabled
So about a month ago I noticed that my speeds dropped dramatically. I specifically noted that no matter what I did, I couldn't break the 215ish mpbs.
So I did the standard stuff:
  • plugged directly into my ATT router and immediately went back to 1gig.
  • Configured my old router and removed the Nighthawk and immediately back to 1gig
  • Rebooted my router
  • Updated the firmware
Blah blah but nothing worked.
Well then I decided to reset my router. Initially this helped and I was confused at to why but then thought, meh who cares.
However, as I reconfigured my router I ran a speedtest. Yeah 969mbps and I could repro that so I thought I was good.
I then went and re-enabled Access Control and set the default, block everything, and then I allowed the few devices I still had connected and hit Apply.
After the reboot I was limited again to under 215 mpbs, so I was like what the heck.
Immediately went back and rebooted the router but same issue (with Access Control still on)
I then went and turned off Access Control hit apply and it reboots. And bingo back to over 900
Turned it back on, and back down to 215 or less.
So as long as I leave access control off I am fine, turn it back on and immediately my bandwith is limited.
Have had this router for years and I assure you this issue didn't exist until recently
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 11
H20FRKS
Re: R7000 - Limiting Lan Speeds and I figured out why -- Its the Access Control Feature
I am having the exact same issue with using Firmware Version V1.0.9.26_10.2.31
Has anyone been able to resolve this issue without turning Access Control off?
Any help would be appreciated!
Message 2 of 11
H20FRKS
This might be true to some extent, but I have fiber internet and from the NOP I am able to get 958Mbps Download to 945Mbps Upload speeds at my PC, but when I go through my Netgear R7000 with Firmware Version V1.0.9.26_10.2.31 I get 412Mbps Download and 115Mbps Upload speed with Access Control on.
I have used Access Control for years and never had this kind of a problem where I loose 50% of my speed. Something is wrong with the firmware.
Message 3 of 11
H20FRKS
Case850, below are all the tests results. Had to go all the way back to V1.0.9.6_1.2.19 to see an improvement.
Current Firmware Version     V1.0.9.18_1.2.27
Uploaded Version     V1.0.9.14_1.2.25
Axxess Xontrol Off
Download
570.11 Mbps
Upload
515.94 Mbps
Access Control On
Download
198.19 Mbps
Upload
156.20 Mbps
Current Firmware Version     V1.0.9.14_1.2.25
Uploaded Version     V1.0.9.12_1.2.23
Access Control Off
Download
336.62 Mbps
Upload
313.24 Mbps
Access Control On
Download
206.79 Mbps
Upload
230.04 Mbps
Current Firmware Version     V1.0.9.12_1.2.23
Uploaded Version     V1.0.9.10_1.2.21
Access Control Off
Download
553.53 Mbps
Upload
514.31 Mbps
Access Control On
Download
199.65 Mbps
Upload
206.97 Mbps
Current Firmware Version     V1.0.9.10_1.2.21
Uploaded Version     V1.0.9.6_1.2.19
Access Control Off
Download
589.46 Mbps
Upload
503.57 Mbps
Access Control On
Download
382.57 Mbps
Upload
459.64 Mbps
Message 4 of 11
H20FRKS
Access Control Off
Download
570.11 Mbps
Upload
515.94 Mbps
Access Control On
Download
198.19 Mbps
Upload
156.20 Mbps
Access Control Off
Download
336.62 Mbps
Upload
313.24 Mbps
Access Control On
Download
206.79 Mbps
Upload
230.04 Mbps
Access Control Off
Download
553.53 Mbps
Upload
514.31 Mbps
Access Control On
Download
199.65 Mbps
Upload
206.97 Mbps
Access Control Off
Download
589.46 Mbps
Upload
503.57 Mbps
Access Control On
Download
382.57 Mbps
Upload
459.64 Mbps
Message 5 of 11
H20FRKS
Case850,
Sorry for the dealy response. I like the extra layer of security the Access list provides and let's me control what devices are allowed on the network.
Kids can give frinds the wifi password and allow an infected devise on my network.
Message 6 of 11
H20FRKS
Case850,
WOW. yes as they say their is more than 1 way to skin a cat. I like the feature and will continue to use it. You mainatin your network the way you want.
The kids was a simple "use case".
Thanks for the chatting, but I did not post this question here to justify why I use a feature on my router.
Message 7 of 11
H20FRKS
As for the performance issue with/without access control is all due to the router I have 10/100/1000 cards, gig switches and Cat5e cable runing my network. Like I said on my original post when I connect directly to the NOP I get almost 1-gig up/down.
Unless Netgear figures out how to improve the performance and push an update I will need to live with it or replace it. I like the product, but if I replace the router I do not think I will be buying another consumer product and move to an opensource product.
Message 8 of 11
Guru
Some have mentioned reverting back to v1.0.7 FW on there R7000s. Seems to be an issue in recent versions of FW causing slower performances. Something to try.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 9 of 11
H20FRKS
Thank you for the post. Yes if I must move to a platform with better throughput I will be looking at.
1Gbps Fiber > pfsense (build your own) > R7000(AP mode)
Message 10 of 11
JamesGL
Master
Hi H20FRKS,
Please check your inbox. I have sent you a message.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 6438 views
  • 0 kudos
  • 4 in conversation
Announcements
