Reply
R7000 Losing connection to internet reglarly
Dr604
I am experiencing the same issues described in this thread. https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-keep-losing-connectivity/m-p/509183#M1.... It seems 4 years ago the fix was a Beta Firmware from Support.
My router is 3.5 years old and was working fine until about 1 weeks ago.  Ever since then the connection from the Router to the Inernet goes down and a soft or hard reboot solves the issue.  It happens about 2-3 times a day.
I have tried the latest firmware and done a factory reset to no avail.
Since the router is 4 years old i don't think i'm eligible for any direct support.
At the moment i've downgraded to a firmware that is a couple of revisions older to see if that makes any difference.
Is this a sign of a failing router and time to get a new one or is there a possible fix out there?
thanks.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Dr604
Re: R7000 Losing connection to internet reglarly
Just confirming that an older firmware did not solve the issue.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 2 of 5
antinode
Guru
> I have tried the latest firmware [...]
> [...] firmware that is a couple of revisions older [...]
> [...] an older firmware [...]
   Actual version numbers would be more useful than your opinion
of what's "latest" today, or "older" (by some amount, from something).
Message 3 of 5
JamesGL
Master
Hi Dr604,
What is the firmware version of the router you have tried?
https://kb.netgear.com/000057097/R7000-Firmware-Version-1-0-9-30-Hot-Fix
Message 4 of 5
JamesGL
Master
Hi Dr604,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 486 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
