Reply
R7000 New Firmware 1.0.6.28 released
LeKeiser
Luminary
Re: R7000 New Firmware 1.0.6.28 released
Oh and then what do you mean by doing a reset ? With a paper clip at the back of the router, the 30-30-30 thing ? Because if that 's the way, what's à factory reset then ? I mean, isn't it supposed to revert to the original firmware ? Or is there a different reset ?
Message 51 of 321
jflorance
Star
I think I did a factory reset. I used the paper clip in the back for 30 seconds. I did this twice, first time didn't seem to work. It wiped my confuration but left me with the latest firmware. I'm not sure what the 30-30-30 is but my goal was to simple wipe my configuration, not downgrade FW. Does that make sense?
Message 52 of 321
TheEther
Guru
A factory reset only wipes configuration.  It does NOT downgrade firmware.
Message 53 of 321
buddy_t
I lost them too, turning off security they now work on all devices, but of course that is not satisfactory!
Message 54 of 321
buddy_t
All devices connect on mine by just disabling security, of course that is inacceptable!
Message 55 of 321
LeKeiser
Luminary
So you confirm that with the SSID disabled, your devices cannot connect to the network? That you have to enable the broadcast for them to be on the network?
My android tablets and my Kindles can't connect IF the SSID isn't broadcasted. I haven't had the time to check with my laptop running Win10. I'll do that tonight. But since it was working before and I haven't changed their configurations, it has to be the R7000 somewhere...
Message 56 of 321
omoeller
Guide
After playing around with 5.52 and 6.28 both of them did not work for me - which is kind of interesting as I do nothing specail with the router - no guest wlan, no port forwarding - just plain simple WLAN router. Anyway, 6.28 was super looooow on UI, downgraded to 5.53 and lost my 5Ghz - and yes, did multiple factory resets per menue and button and reconfigured manually,. I now went back to 4.28 as it simply seems to do what it is supposed to do. The only interesting thing I came across is that it keeps losing assigned names to WLAN clients when it comes to access management. Good luck all ...
Message 57 of 321
LeKeiser
Luminary
Hello Smiley Happy
Sorry what do you mean Ultra slow on UI? What's UI? Smiley Sad
I'll have to check in the morning, but my speedtest.net was 200Mb slower than before... But it might be because the servers were... busy.
Message 58 of 321
omoeller
Guide
Hi-ho - with UI I mean User Interface, means menues of the firmware front end - no the throughput. So under 6.28 the whole user interface was pretty slow on response for me - regardless if connecting wireless or wired. Hope this clarifies.
Message 59 of 321
LeKeiser
Luminary
It does and that's what I thought UI was but I wanted to be sure. 6.28 is as fast as the other firmwares for me. At least, not that I could notice.
How was the throughput for you, compared to say 4.28.
Message 60 of 321
omoeller
Guide
Honestly i did not measure throughput in detail - neither WAN nor wireless - in the end it looked like 6.28 was stable on 2.4 but shaky on 5 Ghz as I had recent connection drops. This turned to be worse with 5.52 but runs perfect under 4.28 I am now back with.
And as said I always did full 30-sec resets before and after upgrade incl. manual re-config....
Message 61 of 321
TheEther
Guru
@Babylon5
@JamesGL
Can one of you replace the 1.0.5.44 sticky thread with this one?
Message 62 of 321
JamesGL
Master
Hi TheEther,
I have requested already to set this thread to sticky thread.
Message 63 of 321
joprix
Guide
For those of us that have lost one or other 2.4Ghz or 5GHz bands, what do we do to get it back? Just wait for another update to fix the update? Re-apply the update, if that's possible? What?
Message 64 of 321
chascent
Luminary
Take my advice :
perform factory reset
load  R7000-V1.0.4.28_1.1.64 firmware
Perform factory rest
Done
   This is the most stable trouble free firmware for the R7000 period. These additions of Arlo camera,
network steering etc are not working and causing other problems. I did speed tests with the
R7000-V1.0.4.28_1.1.64 vs the latest and there ia no difference. The 28 firmware is rock
solid. Just try it.
CC
Message 65 of 321
joprix
Guide
Thanks chascent,
I think I have no choice anyway, now I can't even log in to the router admin page and for a short time I even lost my 5Ghz signal too.  I have to say, this is pretty bad form by Netgear.
Not impressed.
Message 66 of 321
shamarin
Virtuoso
Do a hardware reset of your device. Press a reset button on router and stay pressed for 30 seconds till LED's began to blink. After reseting install your router again. It should work normally.
Message 67 of 321
edgrsanchez
Guide
It doesn't, even after a factory reset after upgrading to 1.0.6, the issues come back. I can't access the router's GUI.
Message 68 of 321
ankydu
Guide
Try this. I have the same issue. The router page will be accessible from your wifi laptop or mobile phone. Access the router over wifi and change it to wireless AP mode from router mode. Once the router reboots it becomes accessible via lan also on your desktop. But please make sure you have another router with dhcp enabled and connected to your r7000. For me this was the only way to access the router after several hard resets. Even restoring the 1.0.4.28 firmware and resetting the router does not fix this. Please confirm if this worked for you.
Message 69 of 321
edgrsanchez
Guide
Nope, can't connect to it via mobile either.
Message 70 of 321
ankydu
Guide
Did you try flashing 1.0.4.28 firmware and resetting?
Message 71 of 321
LeKeiser
Luminary
hello,
Out of curiosity, why do you want to access your router with this IP? After a reset, should be 192.168.1.1, right?
Message 72 of 321
edgrsanchez
Guide
My AT&T Uverse modem uses 192.168.1.1 as its IP and assigns 10.0.0.1 to the router via DHCP.
I just prefer using 10.0.0.X for my home network. Even after doing a factory reset on the R7000 it detects that my router is assigned 10.0.0.1 and sets itself up correctly.
Message 73 of 321
LeKeiser
Luminary
Mmmmh... I see. Weird configuration though, I think.
I have configured my cable as a bridge, so the R7000 gets the public IP, and I assign its private IP myself.
At least I wouldn't let the modem attribute the private IP...
Have you tried to set it up yourself? No DHCP, fixed private IP?
Message 74 of 321
Bersaglio
Tutor
1. You should configure AT&T Uverse modem as a bridge. Or disconnect (temporarily) a cable between this modem and WAN port of R7000.
2. Do another factory reset of R7000.
3. Try to connect (from internal R7000 network of course) using a browser via 192.168.1.1 address or via routerlogin.net
Hope this helps.
Message 75 of 321
Announcements
