Reply
R7000 Nighthawk Router fastest configuration setup
Mwarren16
Follower
Hello, I have the Nighthawk router and it doesn't seem to be going the fastest that I truly believe it's truly cabable of being,  Can anyone  show or help me with making it blazing fast?  I'd be extremely grateful.
Matt
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
TheWorstPing
Apprentice
Re: R7000 Nighthawk Router fastest configuration setup
please be a little more specific. do you mean blazing fast being thrown down a staricase because the wifi speeds drop shortly after rebooting the router that makes one pull their hair out after they bought a $250 router that has these problems?
or do you mean something like you have a gigabit connection and you feel that your download speed don't always get close to 900mbps so you want to see if you can enable any settings that allow it to perform better
Message 2 of 3
What speed does your ISP promise?
What speed do you get?
Is it faster if you measure the speed directly at the modem without the router?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2764 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
