- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 No attached devices V1.0.11.126_10.2.112
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not see any connected devices with this newest firmware. I am unable to use Spotify Connect as it sees no devices. I flashed the router back to an earlier version of firmware and all works as it should. Has anyone else seen this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 No attached devices V1.0.11.126_10.2.112
Hi Bama92, please try resetting the device back to factory defaults after updating to the latest firmware and check if the issue will persist.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
This fixedd the attached devices however Spoitfy connect on my laptop shows no devices. Phones and tablets work fine.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the laptop connected to the same band (2.4GHz or 5GHz) as the other devices?
Are you using a VPN service for the laptop?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
I am not using a VPN. Everything is connected via 2.4. This all happened with the last firmware update. As I stated before I can flash the router to an earlier firmware and Spotify Connect will then work on my laptop.
Regards
