Reply
R7000 Privacy Concerns
Retired_Member
Not applicable
Hello,
Once again netgear is doing odd things. Recently with update V1.0.9.42 on the R7000 every 4 seconds the router will send a ping home checking the connection against netgears servers. The serial console is being spammed by pings home, I have turned off analytics, and there's no reason why this router needs to be checking the connection like that. I would understand if I had analytics enabled but I don't, and it's not even in router mode I'm using this in access point mode.
I previously saw that even with analytics turned off the router was still attempting to send data. (https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Analytics-Turned-Off-But-Still-Sending-Data-...)
Please disable this...
PING www.netgear.com (52.84.94.97): 56 data bytes
64 bytes from 52.84.94.97: seq=0 ttl=240 time=26.290 ms
--- www.netgear.com ping statistics ---
1 packets transmitted, 1 packets received, 0% packet loss
round-trip min/avg/max = 26.290/26.290/26.290 ms
ping -4 -c 4 -f www.netgear.com success.
PING www.netgear.com (52.84.94.247): 56 data bytes
64 bytes from 52.84.94.247: seq=0 ttl=240 time=25.060 ms
round-trip min/avg/max = 25.060/25.060/25.060 ms
PING www.netgear.com (52.84.33.49): 56 data bytes
64 bytes from 52.84.33.49: seq=0 ttl=241 time=13.066 ms
round-trip min/avg/max = 13.066/13.066/13.066 ms
64 bytes from 52.84.33.49: seq=0 ttl=241 time=13.789 ms
round-trip min/avg/max = 13.789/13.789/13.789 ms
PING www.netgear.com (52.84.33.222): 56 data bytes
64 bytes from 52.84.33.222: seq=0 ttl=241 time=14.128 ms
round-trip min/avg/max = 14.128/14.128/14.128 ms
PING www.netgear.com (52.84.33.221): 56 data bytes
64 bytes from 52.84.33.221: seq=0 ttl=241 time=16.170 ms
round-trip min/avg/max = 16.170/16.170/16.170 ms
PING www.netgear.com (52.85.89.75): 56 data bytes
64 bytes from 52.85.89.75: seq=0 ttl=240 time=12.386 ms
round-trip min/avg/max = 12.386/12.386/12.386 ms
BusyBox v1.7.2 (2018-09-06 15:12:04 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# version
Release version : 802.11ac Dual Band Gigabit Wireless Router R7000
                  U12H270T00/V1.0.9.42/10.2.44
           Time : Sep  6 2018 15:13:53
Message 1 of 4
bascaves
Apprentice
Re: R7000 Privacy Concerns
Indeed this sound like a ridiclous 'call-home-feature' which as user you can't even control.
Netgear this is a bad practice.
Many vendors and software makers (even ones you have trusted for a long time) start lately implementing all kind of remote checks/datacollections/control which from all aspects including privacy is doubtful.
I.e. for me CCleaner lost all my faith with their stunts. So netgear doesn't stand alone in these practices.
Brgds,
Bas.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 2 of 4
Retired_Member
Not applicable
bump
Message 3 of 4
Retired_Member
Not applicable
In V1.0.9.60 this is still an issue, as well as the my other thread about the analytics still connecting to Netgears AWS server to ping home saying the analytics is disabled which gives them the SN#, my IP, my geolocation via IP (which is very accurate these days).
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1049 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
